Farmall Tractors Discussion Board
Super C Electrics
Posted by T'Other Fred on October 17, 1999 at 21:09:01 from (206.72.4.94):
There also a couple of oddities with the tractor's electrics. As I said, a service manual will be coming but in the meantime...
The tractor has an alternator. Voltage at the battery yesterday was 12.7 with one cable off, 12.50 with the cable attached and engine running.
There is a large ceramic resistor but no external regulator visible so I guess it is internally regulated. Perhaps whoever made the mod thought a system designed for six volts would be OK with the battery less than fully charged. (?)
The ignition switch didn't kill the engine, so I choked it, disconnected the negative cable, and looked around. All the wires have been cut at the switches and lamps. Not sure if that was to avoid durning out lamps with the higher voltage, or due to concern about positive vs negative grounding.
The ignition is hotwired somewhere. The starter works ok.
There is a six inch long wire attached to the outside of the distributer. It seems it might be the ignition wire but I'm not sure.
A pressure switch is connected at a T beside the oil pressure gauge, with wires running up near the battery. I haven't traced them yet but the local antique Caterpiller man thinks they may be intended to isolate the alternator from the battery when the engine is stopped.
I'd like to chat with anyone who has insight into these sorts of things!
Fred
Post a Followup
: Re: Super C Electrics
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
