Re: Re: fast hitch
Posted by Hugh MacKay on February 18, 2004 at 19:09:48 from (64.228.11.1):
In Reply to: Re: fast hitch posted by scotc on February 18, 2004 at 17:36:37:
Scot: You do have a good suggestion as the frames of those two plows are the same. The only part different is the pull beam and it is interchangable, so he could make up a single point fast hitch pull beam for the plow without destroying the 2 point pull beam.
As far as picking up plow or disk I wouldn't worry about breaking anything as Super A will not lift that much. I have a single point 6' S tine cultivator I fabricated, 18 teeth on three tool bars. I did intend building or buying a crumbler. I now have 6.5' heavy angle iron with chains on each end to pull it for leveling and crumbling. When I leave field I throw the heavy angle on top of the cultivator. I have to place this quite close to hitch point or these little tractors will not lift the cultivator.
I also have a 60 gallon sprayer, with 20' boom. I fabricated the mounting so weight is as close to tractor as possible. If that sprayer is full, I have to push on hydraulic lever then lift by hand on sprayer. These tractors will lift it with my hand help. However I do have concerns re the strength of hitch linkage so I use two chains to carry weight while spraying.
Super C and 200 using a remote cylinder for the hitch will lift substancially more than the Super A, 100, 130 or 140 with the touch control rockshaft. These little tractors fall down on lift quite quickly when the weight is back 3' or 4' from hitch point.
Post A Followup
: Re: Re: Re: fast hitch
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
