Re: crankshaft main caps on farmall super m
Posted by Stan(VA). on February 07, 2004 at 20:18:06 from (208.59.157.190):
In Reply to: crankshaft main caps on farmall super m posted by keith h. on February 06, 2004 at 22:38:33:
None of the motors I have had the 'pleasure' of dealing with this problem on (3 so far, 2 with mains swapped, 1 with rods swapped) have had the main caps marked, which I suppose is why it's so easy to mix them up. On the two with mains swapped, both had the thrust cap in the right place, but the other two were swapped. Anyway, if your motor is still on the tractor with crank in place, and inserts still in the caps, then you know where the thrust cap goes (thrust bearing is the 'C' shaped one with sides), you will have to measure clearances (plastigauge, etc) to determine proper place for the other two. If motor is totally dissasembled, again, start by identifying the thrust cap which should be the center cap on this motor (center cap on H/M series, rear cap on A/B/C series). (there should be two caps with similar casting marks and one that's different, that is the thrust cap.) You also need to know what direction they face. You often get lucky if the bolt holes are slightly offset drilled on the thrust, the sides will not line up when on the wrong way. Once you find that one you can usually go by casting numbers facing the same way to get the others that might not be so obvious. You will need to measure the diameter in each bore and do a select fit to find proper place for the front and back caps. Good luck, Stan(VA).
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
