Re: bought 100
Posted by Hugh MacKay on January 24, 2004 at 18:01:18 from (209.226.106.189):
In Reply to: bought 100 posted by jeeper on January 24, 2004 at 16:33:01:
jeeper: Here are a list of the fluids an amounts. Cooling system 15 qt., Fuel tank 11 gal., Crankcase 5 qt., Transmission with pto 5 qts. gear oil, Steering box 1 qt. gear oil, Air cleaner cup 7/8 pt. motor oil, Touch controll hydraulics unit dry when new 8-1/4 pt. refill system 6-3/4 pt. hy tran. Rear axle drive housings (each) 3 pt. gear oil. One of the first items you should do is refill fan hub with oil. there is a screw on side of fan hub. Turn fan so screw is pointing to horizontal position. Remove screw and fill with motor oil to level of screw. Then turn fan so fill hole is on bottom, this drains off excess oil. Replace screw. On the side of your distributor you will see two plugs with blade screw heads. These are the size for large grease zerks. Some people install zerks. It is not generally recomended. An IH technician once told me best to get a tube of white automotive grease, remove the plugs and squeeze a small amount in holes, and only do this once per year. Too much grease in there and it will force through to distributor or governor. Do those two items before you use a tractor that has been setting for 10 years. Good luck and if you have any questions, just ask.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
