Re: Cracked Block on A/B/C etc. Farmalls?
Posted by lee on January 24, 2004 at 15:12:52 from (24.24.92.235):
In Reply to: Cracked Block on A/B/C etc. Farmalls? posted by Al on January 24, 2004 at 14:24:10:
Which way is it running, horizontal or vertical? How long is it? Is it directly behind the carb? Critical areas internal to the block about midway betweel the oil pan gasket surface and the head gasket surface are the O-ring grooves that seal the bottoms of the sleeves. These O-rings seal oil from getting in the coolant and coolant from getting in the oil. This crack if in the right place could pass thru an o-ring groove and then you may have a problem. It may not pass thru either, depending on where it is. It may or may not be a problem but I would evaluate it closely before I bought it. Casting cracks can grow over time, but they may not grow either. They can have a mind of their own. You can get a better idea of it's location relative to the o-ring grooves if you have access to a used block or if you can get a look at scaled section drawings showing the front and side sections of the engine assembly. If it is a short horizontal crack and above the o-ring grooves it may not be a problem other than keeping JB weld in place. Check the oil and coolant closely for coolant in oil or opposite. You will likely want to drain the systems to check. Oil floats on water so any coolant in the oil would be at the bottom of the pan. You could pressurize the radiator slightly as another test to see if coolant is transfering to the oil.
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
