Farmall Tractors Discussion Board
What to use to protect the electrical connections?
Posted by Marvin on October 06, 1999 at 10:34:11 from (134.134.248.18):
The starter was intermittently not turning over the engine on my Super A so I pulled out the multimeter and found that I had 2 volts of drop in the ground path to the starter. I pulled the cables and other pieces of hardware and took them over to the wire wheel and cleaned every thing up. Put it back together. The starter turned over much better then. I then emptied the glass bowl under the tank and wiped out the little pieces of rust that had accumulated. Seems like this winter will be a time to etch and seal the tank.
I then tighted up the fan belt.
Checked the points and adjusted them. Found also that the condenser was loose in it's holder, so I tighten that up.
I then installed the new headlight bulbs that I had purchased. Turned on the switch and nothing. Wiggled the fuse holder and they came on and off. When I got them on, I went over and bumped the headlamp holder and they would go on and off. So I have some more cleaning of grounds and of switch connections at the dash.
After I get all of the connections clean, what do I put on them to keep them from being rusty and oxidixed in another six months?
Post a Followup
: Re: What to use to protect the electrical connections?
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
