Re: H engine rpm's surge.
Posted by Bob M on December 10, 2003 at 06:53:44 from (165.170.128.66):
In Reply to: H engine rpm's surge. posted by Jake on December 09, 2003 at 20:20:33:
Jake - First thing to do is make sure the carburetor is properly adjusted. If the idle mixture screw is set too lean and the power screw too rich the engine can surge under light load conditions. But assuming the carb is set OK here's some things to check: 1 - Loosen (don't remove) the two clamp screws at each end that fasten the tube running between the governor riser and the carburetor. Wiggle the tube around to make sure it's free, then retighten all 4 screws. 2 - If that doesn't help, remove the slanted cover from the top of the governor riser to expose there the bell crank inside. With the governor handle set at "idle", try moving the bell crank up and down - it should move freely. If it does not, check for a binding in the crank pin or bellcrank bushing. 3 - If it still surges, disconnect/remove the carburetor from the manifold. Check for free movement of the throttle shaft - it should rotate freely without a hint of binding. If it does not, time for a carburetor rebuild. 4 - If after all the above the engine still surges, the problem's inside the governor itself - a binding output rock shaft, sticking thrust bearing, worn flyweight pins, etc.
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
