Farmall Tractors Discussion Board
1066 Range transmission
Posted by Richard Rahmier on October 05, 1999 at 14:46:00 from (199.217.177.91):
Ever since I have owned this 1066 it wood jump out of reverse. So last night I took off the top cover where the linkage goes through, and found the spring that goes on the shifter arms was off
and one of the roller cams was broke. So I took it apart and welded the stud that the cam rolls on
Thinking this solved the problem I put it back together only to find out it still jumps out of gear. It seems to go past reverse you have to move the shifter back towards the neautral locationto get it to move in reverse. But some times it will go in gear the way it suppose to. I was wondering if I would put it together and move the splined shaft going down to the shifter fork a little one way are the other will help. Can you take the plate off the side of the case and see the reverse gear?
Post a Followup
: Re: 1066 Range transmission
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
