Re: power steering farmall 560
Posted by Aces on November 09, 2003 at 13:22:55 from (67.0.7.212):
In Reply to: power steering farmall 560 posted by J. Klein Rot on November 09, 2003 at 10:24:34:
Klein This will take a little time but I will try and help. If I unstand what you are saying is you can get some wobble in the front wheels. The 560 has a rack and pinion steering with a ball worm screw for manual steering. The rack is in side a sleve that is an eccentric sleve. That means you can adjust the clearence of the rack and pinion but rotating the sleve to move the rack closer to the pinion. In order to do that you will have to remove the left hand side rail. You will have to remove the steering shaft.The steering is held in place bu 4 hex cap screws, then you can see the flange of the sleve and a notch to help turn it, this is where the hard part comes in if it has not been apart in a long time the sleve could be very hard to turn and you can brake it if you get too hard on it. You may have to take the complete steering apart to do this so you can free it up. The other problem could be the bearings on the pinion or bolster shaft could be loose. To get at that you need to pull the radiator and the frame it sets in, that will on cove the bolster shaft. As for hard steering could be the pump or the ball screw shaft is not free to move in and out of the steering housing to ativate the hydraulic valve. So rock the shaft from the steering wheel back and forth to see if the ball screw shat is moving in and out if not the valve will not open and let oil flow for power steering. If you get a I&T manual this should make more sence to you. Hope I helped some. Repost if I can help more.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
