Re: M propane tractor
Posted by novice on November 01, 2003 at 15:54:48 from (207.221.160.217):
In Reply to: M propane tractor posted by Buck on November 01, 2003 at 13:09:26:
Buck: I found myself in this same position recently. The tank should have 2 handwheel valves, one which releases vapor off the upper part of the tank and the other which releases liquid off the lower. Although on the same level on the outside of the tank, one has an internal dip tube inside which goes up insidew and gets vapor off the top of the tank and the other a dip tube which goes down and draws liquid off the bottom. The outside temp always maintains a vapor cap over liquid inside the tank. The tank's internal vapor pressure is what pushes liquid out the liquid line to the regulator. In addition to the handwheels, there should be two yellow plastic caps screwed over filler valves with spring loaded checks inside used to fill the tank. The tractor needs to be started with just the vapor valve open. It should hiss momentarily when opened till the diagphram is compressed. Once the tracor is started and warmed up, the liquid line can be opened, and the regulator will begin receiving liquid which will vaporize due to the heat of the engine coolant circulating through the Ensign regulator now that the tractor is warmed up. Then you can close the vapor handwhhel. The pressure gauge on the tank will read vapor pressure in the tank which will depend on the outside temperature (should be about 150 psi when 75 deg F outside). There may also be what looks like a rotating float lever (its mounted on a hollow stem) with a dial behind it indicating what percentage of the tank has liquid in it. This lever actually has no float on the end inside, rather it has a hollow tube connected to it that, when rotated and pointed up, will vent vapor out the relief tattle-tale screw on the end of the lever. As the lever is turned, the tube inside will dip down into the liquid and white frosty liquid will begin to come out the vent instead of vapor. The position at which this occurs will tell you how much liquid is in the tank by reading off the dial. Be careful as the liquid is very cold and the valve should also be opened just enough to hiss vapor when measuring volume. Point away from your eyes and uses gloves. The tank should also have a spring loaded relief valve in case of overpressure. No cap should be in place over this relief. I dont even think it's threaded for one. There may also be a small valve to crack open when filling the tank to prevent compression of the vapor in the tank. When liquid comes out this valve, the tank is "full" and filling should be terminated to leave a vapor cap inside. The tractor will run on vapor but will have more power on liquid. If you get the right connections and hoses, you can fill your tractor of the LP tank that feeds your house (if you live in country and have LP tank). Be sure the tank has an internal liquid line so that the vapor pressure in the big tank forces liquid up the liquid diptube, through the hose and to the tractor. Most rural LP Propane/Butane companies can rig this up for you.
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
