Re: Converting 1948 Farmall Cub to 12 Volt System
Posted by steve on October 20, 2003 at 19:55:18 from (204.246.222.148):
In Reply to: Converting 1948 Farmall Cub to 12 Volt System posted by Doug on October 19, 2003 at 18:18:04:
Doug, the conversion is very easy. the hardest thing is mounting the new alternator and aligning the pulleys so the belt runs straight. The most common alternator is the DELCO 10SI, you can get this from a 1975-85 chevy car or truck. Sell them at auto parts store for $40. just make sure it is the internal voltage regulator type built after 74 or 75. ---You run a heavy wire from the bug 1/4 inch lug on the alternator to the battery + terminal, usually thru the amp meter. you also put 12 volts to the #2 terminal on the alternator. the #1 terminal (spade terminal) as 12 volts when running, but is switched off by a key or toggle switch when not running. You can also use a smaller japaneese type alternator if you wish. main thing is to find which terminal is the "signal" or switched on and off with 12 volts. Starter dont care if tractor is 6 or 12 volt or + or - ground. --change all 6 volt lights to 12 volt--- all a dropping voltage resistor to the ignition coil if you have a distributor so you maintain 6 volts to the coil. if you have a magnito, dont worry.-- if you need more info, just ask.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
