Re: Re: Re: H that keeps running after it is shut
Posted by Steve - IN on September 28, 2003 at 18:26:52 from (12.222.30.13):
In Reply to: Re: Re: H that keeps running after it is shut off posted by the tractor vet on September 28, 2003 at 17:14:29:
tractor vet,
You might be right, but it's Sunday and so I was being charitable by assuming his handyman knew what he was doing. Least nothing was mentioned about his changing the ignition timing.
If the plugs are the wrong heat range, or just not torqued down right so they've become "glow plugs"; he could just reinsall the old plugs and see if that cures it. Another idea would be to retard the ignition timing a bit, as I think every 5 degrees of advance can raise chamber temps by 75 to 100 degrees. Net cost of the above is zero -- the kind of fixes we like!
Maybe the best advice is to read the color of the exhaust smoke and/or pull a plug and compare it to one of the hot/right/lean series of pictures of plugs here on the web. I don't know if plug gap or dwell is going to be a make or break item on a low compression non-turbo engine, but your main point seems to be that the cause or the cure can be on either the fuel or the fire side of the engine; and that's the truth.
Post A Followup
: Re: Re: Re: Re: H that keeps running after it is shut
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
