Re: i h 584
Posted by JB on August 10, 2003 at 10:06:10 from (24.157.143.182):
In Reply to: i h 584 posted by william p on August 09, 2003 at 05:04:41:
Hi, can you determine which cylinder is missing? If you can determine which cylinder is missing do an injector swap to another cylinder and see if problem follows injector. CAUTION: FUEL LINE FROM INJECTOR PUMP IS UNDER ABOUT 2100 PSI PRESSURE and WILL PENETRATE SKIN AND CAUSE BLOOD PIOSIONING. WEAR PROTECTIVE GLOVES and EYE WEAR WHEN DOING THE FOLLOWING. To determine bad cylinder will engine is running loosen nut on fuel line into injector util fuel leaks. If engine runs worse this is not bad cylinder. Re-tighten nut and try the next cylinder. Repeat until you find bad cylinder. Then shut off engine and mark and swap suspect injector with another cylinder. Becareful to tighten the two hold down nuts on the injector evenly so injector will seat properly. Leave the input fuel line nuts on the swapped injectors loose to allow bleeding of air. Start the engine again and tighten the fuel line nuts on the injectors. Repeat the test for bad injector but now only doing on the two cylinders that you swapped injectors on. Does problem follow injector or cylinder ? The good news would be that the problem follows the marked injector. Bad news is cylinder. BE CAREFUL WITH HIGH PRESSURE DIESEL FUEL JB
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
