Re: Re: Bearings for Farmall MD belt pulley
Posted by Wayne Swenson on July 27, 2003 at 21:14:04 from (66.228.233.207):
In Reply to: Re: Bearings for Farmall MD belt pulley posted by Wayne Swenson on July 27, 2003 at 21:08:47:
Here is the message posted earlier: My 2 sons & I just re-did 2 gearcases for their belt pulleys on their "H"s". Remove three capscrews under the pulley mounting flange and the shaft, spacers, & bevel gear will all slide out with a bit of assistance. Remove the cap screw on the end of the shaft and all the parts can be pulled off. I was able to obtain replacement bearings at no cost by going to an electric motor rebuilding shop. If my memory is corect you need a 6210 & 6208 bearing for the drive shaft. Remove any shields so the bearing will now lube itself from the transmission oil. Thoroughly clean all old grease residue before installing the used bearing. Factory bearings run $50 or so for the big one so it can be an expensive affair to replace them. NAPA wanted $45 for the 6210 size. I have a Case/IH dealer in town (Fergus Falls, MN) so otained the new seal, felt dust washer, and mounting gasket from them at a very reasonable cost. Carefully clean the metal spacers and put a VERY light coating of silicone on them just before assembly. Don't mix up the cap screws from the drive gear cover with the shaft cover; they are longer (don't ask how I found out) and will not compress the spacers under the pulley flange. On the drive gear shaft,just remove the 3 cap screws and pull the unit out. Remove 2 fine threaded cap screws & take the bevel gear & bearing off. It is a 6206 size. Watch out for the shift lever plunger & spring as they will jump out if the lever is moved too far. And this will happen as you clean the gearcase. If you need to replace the steel plug in the back of the gearcase, IH doesn't have it any more. Go to an automotive parts rebuilder and get a 1 3/16" soft plug; it can be deeper (longer) than original. Put the spring & plunger back in place, set the large drive gear on the shift lever. Clean & lightly silicone the spacers and reassemble. The 2 long bolts had copper washers but a dab of silicone will work. Be sure to put them in place in the gearcase BEFORE you slip it into place on the tractor. They won't go in later unless you remove the gas tank or pull the gearcase back out. (I know, experience is a great teacher) It goes without saying to carefully scrape all old gasket residue off before reassembly. Careful use of a 10" or 12" mill file will do wonders. Use it as a draw file ( sideways motion, not forward & back) to locate any high spots on the metal casting also. I now have 2 belt pulley gearcases that work just like new at a very minimal cost. Sorry for the long post, I was a Vocational Engines instructor in my past life and just can't quit teaching!! Good luck.
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
