H front wheel bearings
Posted by '43 h on July 22, 2003 at 14:51:54 from (216.240.84.190):
Continuing a long term restoration on my 1943 H, I worked my way to the front wheels. Found that one hub was original clamp type, other was later bolt on. Found a second clamp type but discovered that the inner bearing race (the big one) on both clamp hubs was loose, i.e. would rotate by hand within the hub. Both outer races are OK, i.e.smooth and static. One inner and one outer bearing set required replacement. I have ordered a couple of inner races and the circular oil seal ring which is pressed in ouside the race (#7 in the IT manual on P-10) Question #1: Is it likely that the wear permitting the rotation is confined to the machined steel race, or is the cast iron hub also worn? I have had one opinion from a tractor mechanic that the hub may be worn too... If the hub is also worn, and the new race doesn't fit snugly, is there any remedy aside from Lock-tite? Question #2: What is the preferred method of removing the oil ring seals...i.e , should they be tapped out from the inside, or should the be yanked out from the outside??? Both hubs have what appears to be a sheet metal seal inside the outer bearing race and one also has the seal inside the inner bearing race. These do not appear on any schematics of the H axle that I have seen, so I assume they are aftermarket..they are also apparently non-functional as the axle hole is extremely distorted and would not work as a seal....
Question#3: Should I remove these while I am working on the races?? Any and all help is most appreciated...
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
