(A) HEADGASKET WOES, HELP !!
Posted by JON MIRGON on May 17, 2003 at 16:24:50 from (66.119.33.170):
FINISHED THE COMPLETE REBUILD ON MY A ENGINE WITH ABOUT 1,200.00 INVESTED, AND I CANT GET THE HEADGASKET TO SEAL. THE HEAD AND BLOCK WERE CHECKED AND OR MACHINED BY A MACHINE SHOP SO I FEEL SAFE IN ASSUMING THAT THE HEAD IS NOT WARPED OR THE BLOCK. THE FIRST TIME THE HEAD GASKET WAS LEAKING VERY SLIGHTLY EXTERNALLY, SO I RETORQUED IT AND TOOK THE TOURQUE UP TEN FT LBS TO 75. STILL LEAKING EXTERNALLY. TOOK THE TOURQUE UP ANOTHER 10 FT LBS, STILL LEAKING EXTERNALLY. DECIDED TO START ALL OVER AND ORDERED A NEW HEADGASKET, REPLACED THE GASKET AND USED PERMATEX SEALER THIS TIME. GOOD ! NOT LEAKING EXTERNALLY ANYMORE BUT NOW I AM GETTING WATER IN THE OIL !!. TOOK THE TOURQUE UP TO 75 AGAIN, CHANGED THE OIL , SAME PROBLEM, TOOK THE TOURQUE TO 85 FT LBS AND NOW ITS LEAKING INTERNALLY AND EXTERNALLY !! AND THE MOST DISAPOINTING PART IS THAT IT RUNS GREAT. JUST NEED TO KEEP THE WATER WERE IT BELONGS. BEFFFORE I GOT THE RADIATOR ON I HAD TO HEAR IT RUN SO I RAN IT FOR ABOUT 5 MINUTES WITH NO WATER ON SEVERAL OCCASIONS ANY CHANCE I WARPED OR CRACKED SOMTHING ? ANY HINTS HELP SUGESTIONS OR WONDER SEALERS GREATLY APPRECIATED.
THANKS JONATHAN MIRGON
Post A Followup
: Re: (A) HEADGASKET WOES, HELP !!
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
