'H', Differential Seal, and Drive Gear Questions.
Posted by Fred KS on May 13, 2003 at 16:29:20 from (64.39.205.106):
Pulled my brake cover and found the shaft oil seal leaking. Removed the seal and found that my roller bearing was about to start spitting out ball bearings. Decided to go ahead and replace both differential shaft ball bearings on both sides, which brings me to these two questions.
Since I'm going to pull the bearing cages, would it be easier to remove the oil seal once the cage was out? I'm thinking I could drive the seal out once the cage was removed.
Also, is the bolt holding the right hand drive gear a right or left hand thread? I know the bolt on the left drive gear is right hand thread, but the parts catalog shows two part numbers for the bolt with no referrence why.
Thanks,
Fred KS
Post A Followup
: Re: 'H', Differential Seal, and Drive Gear Questions.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
