Farmall Tractors Discussion Board
Re: 'A' PTO SHAFT SIZE
Posted by ltf in nc on September 08, 1999 at 21:29:54 from (206.228.213.189):
In Reply to: 'A' PTO SHAFT SIZE posted by TIM LUCAS on September 08, 1999 at 20:41:53:
I just bought an overruning clutch for an old ford that I like very much as it is easily installed and removed. It had the 1 1/8" dia. 6 spline and was $41.90 delivered and I had to pay tax as it came from in state. The larger 1 3/8" dia. unit is a couple of dollars higher. My old ford did not have the side groove for the latch pin but it only took a few minutes with a side grinder to grind a small radiused groove in one spline of the pto shaft. If the unit you had did not fit because it was too small you will need the 1 3/8" size. To my awareness there are only two sizes for 540 rpm pto's. Your source for the above referenced over running clutch is 1-800-345-0169. I am not connected with this source, just a satisfied customer.
Post a Followup
: Re: Re: 'A' PTO SHAFT SIZE
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
