Posted by MN Scott on March 28, 2009 at 20:31:08 from (206.9.216.34):
In Reply to: Farmall 826 posted by farmall650 on March 28, 2009 at 11:32:18:
The German 358 for its size in the 826 is one of the most fuel efficient engines IH made, as a matter of fact all the German's are fuel sippers. As for the 358 being a money pit I have to take issue. If you compare overhaul kits for the 358 and the 407 in the 856 you will find the german kit is actually cheaper. The german is a wet sleeve versus the 407's dry sleeve. A wet sleeve engine is very easy to overhaul, slip the old sleeves out clean things up and slip in the new ones. A dry sleeve is a different story. The dry sleeves have to be fitted just right or the piston will seize and chuck a rod thru the block. The only spendy item on the German is the fuel injector pump. Some parts for the pump are no longer made so they are high priced and hard to find.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
