Farmall Tractors Discussion Board
starting problem on M
Posted by DonO on August 24, 1999 at 11:06:51 from (206.196.56.101):
I recently bought a 1946 M tractor to use as a second backup tractor. Because it may set for along time between uses, and beacause it has a magneto, I figured I would forego the cost of a new battery, wiring, lights, etc, and just start it with the when needed. I then noticed the portion of the sleeve that engages the shaft had been torched off. I pulled th bolster off (not a fun job) and replaced the sleeve with a used sleeve from a tractor salvage yard. When trying to put the bolster back on, I noticed the sleeve was too long and would be permenantly engaged to the . The used sleeve a got was the same length as several other sleeves I saw on other M's. The shaft looks normal on my tractor also. It appears the only way to solve the problem is to shorten the sleeve. Has anybody else had this problem or know what I'm doing wrong?
Post a Followup
: Re: starting problem on M
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
