Posted by Janicholson on March 28, 2009 at 06:40:41 from (66.173.50.8):
In Reply to: I broke my 300U posted by badaugherty on March 28, 2009 at 04:52:49:
Amp meters should not spark because they are not connected internally to ground at all. If they spark it is because they have either an internal fault to ground (internal insulation bad)or a connection is loose or corroded. If you have a Ohm meter, disconnect both sides of the amp meter and see if there is a path to ground between either terminal, and the case of the meter. If there is any reading on the meter (should show the same reading as if the leads were not connected) the meter is bad. Now do the same across the meter terminals this should show no resistance, (meter should swing full scale, or go to 0 (or near 0) ohms. If it has no conduction it is bad, if it reads full swing, or Zero (or near) it is OK. Check those wires for clean shiny ends, and proper size. The wire to the amp meter from the starter relay should be 10 gauge. The wire from the amp gauge to the alternator big terminal should be 10 ga. It needs the light or diode to make things work correctly, do not use it without that feature. (it might work, but it might give un expected results (like not shutting off). Be patient, be thorough, and keep us informed on what is happening. JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
