'50 H Electric Help!
Posted by Krey in Indiana on October 02, 2002 at 10:56:40 from (12.220.204.241):
I converted my H to 12 volt negative ground this weekend. Swapped generator for a Delco 10 SI Alternator. Also added Ignitor electronic ignition and a high output 12 volt coil (All from Steel Wheels Ranch). Replaced all relevant wiring with new in the process, new ignition switch, and new starter & battery cables. Now for the questions:
-The installation instructions for the Ignitor electronic ignition kit say to adjust timing after the installation. Is this necessary? If so, how?
-When first started, the ammeter read 14 amps charge, after a while, it dropped to 10. When started later in the day, the ammeter read 20 amps (needle was pinned), then dropped to about 9.5-10 amps. It seems to be staying steady at 10 amps now. Does this mean I'm actually at a slight discharge? Where should I start looking for a problem?
Thanks-
Krey
Milltown, Indiana
Post A Followup
: Re: '50 H Electric Help!
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
