'51 cub update
Posted by Mark Kw on June 21, 2002 at 04:32:35 from (216.222.240.219):
I asked a few days ago about a 1951 farmall cub with a cracked axle housing. Owner decided to chance making the weld repair without disassembling the axle and wheel gears. Took my time, grooved the crack out after removing the previous weld metal from the prior repair. Used a combination of nickle and non-nickle cast iron electrodes. Pre-heat to 450F and post heat for 2 hours at 400F before starting a two hour slow cool down. Repair looks good and seems to be holding well. Thanks for all the help, just wanted to let you know it's much appreciated.
Post A Followup
: Re: '51 cub update
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
