FAA No start checklist
Posted by Joseph P on May 30, 2002 at 05:05:31 from (206.243.130.20):
Battery charged - full.
Plug wires to dist cap in correct order.
Timing: appears to be correct TDC #1 rotor to 1 (I used a small copper wire, and inserted into plug chamber, and rotated fan as wire slippedupward thorough finger and maxed out, observed position of rotor and was in line with #1 on distributor cap.) Assuming that this is compression stroke because I did not remove the megneto or attempt to turn over engine during painting touch up...timing should not have changed).
Magneto appears to be sending "some" current due to light test meter on side shutdown post. But weak light response. Barely flickers as points open and close.
Motor turns over. Starter engages.
6V with regulator (4 contacts/connections).
No spark at plugs.
Gas to plugs. Seems that plugs are a little wet and smell like gasoline.
Waiting on tune-up kit to arrive. Will work on cleaning, tightening the inside of magneto later today and install new points and condensor too. Setting gap to .13.
Will give that a try before I post results.
If I am missing somehting, or if you think of something I am overlooking let me know.
You'all have helped me narrow down the location of the problem (I hope) and helped me better understand magneto system and FAA ignition system. I'm on a steep learning curve, and I need your help to get me there. TYIA. Joseph P
Post A Followup
: Re: FAA No start checklist
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
