Posted by tipper on March 25, 2009 at 17:23:01 from (75.88.202.227):
In Reply to: 574 help posted by bksnowbelt on March 25, 2009 at 11:32:32:
I had the same thing happen to me after I pulled the tank on my 674. I could start the tractor, and it would die after 10 seconds. If I let it sit, it would be ready for another start in a minute or so. It turned out that I broke loose just enough rust and general muck to clog things up. I removed all the fittings from the tank and flushed the tank as well as I could with a lot of water. You would be amazed at what came out. I continued doing this until I could see nothing else floating/swirling around in there. It took some time, but eventually the tank was free of loose crud. As far as not wanting to put water into a fuel tank--I figure I had at least a 1/2 pint of water in there when I started draining the fuel...all 15 gallons. If a pint of water is already there, temporarily wetting it down isn't going to cause any problems. I used a blow gun to help it dry, and after blowing out all my lines, I hooked it all back up. I have not had a problem with it since.
This post was edited by tipper at 17:25:08 03/25/09.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
