Farmall Tractors Discussion Board
'52 Farmall H leaks gas
Posted by Ryan on July 25, 1999 at 17:24:03 from (205.188.196.52):
I have a 1952 Farmall H that used to leak gas around the air cleaner hose that sticks into the carb. We took the carb off and cleaned it and found that the pin that holds the float on popped out so we put it back in and got it tight so it wouldn't come out again. It ran really good for a couple of days and we accidently left the gas on for 30 minutes while it was off and we noticed it leaking again. It started it and drove for a long time though after that. Could a piece of dirt have got in it and caused that or is that normal if you leave the gas on? Anyways, once I parked it I cut the gas on for a few minutes and it didn't leak. I think it was just a piece of dirt but advice would be nice to have.
THANKS,
RYAN
Post a Followup
: Re: '52 Farmall H leaks gas
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
