Posted by Janicholson on March 24, 2009 at 06:43:35 from (199.17.6.128):
In Reply to: re: Brownie 450 posted by Shawn in PA on March 23, 2009 at 17:56:07:
Do not worry about excess RPM, it came out of a car with 3 or 4 times the RPM, and alternators like these are self limiting on output amps. The issue is where the amps are going when the ignition is turned on. I would not change anything until a different good amp gauge was installed. Knowing the real numbers is important in this case. The light bulb test you describe is normal, but does not allow a number to be associated with the amount of draw. A good quality Multimeter will have jacks located on the front to allow a 20 amp load to be placed across the leads. The meter is placed between the battery post and removed terminal (as you did the light bulb. Using that, a good amp meter, or a hold against the wire meter (cheap at the auto parts store), Will measure the actual draw (which should be about 3 to 4 amps with the points closed, and near nothing with them open. JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
