Farmall Tractors Discussion Board
Fuel bowl problem on a Super M
Posted by Ludwig on May 28, 1999 at 05:37:23 from (207.5.172.20):
Super M's gots trouble.
If you screw up and leave the gas on over night the bowl gasket leaks just enough to let the gas evaporate and it'll empty about 2 gallons from the tank. The problem is that then no more gas will flow into the bowl. I can make gas go in like it's right if I kind of ease the bowl over to one side or don't tighten it up all the way, but then it leaks bad. It seems like there must be an air hole of some kind in the bowl assembly, but I wasn't able to find it. The gas tank is reasonably clean, as is the fitting from the tank to the bowl and the valve itself. The screen was a little dirty so I cleaned it with carb cleaner and it looks fine. The gasket was improvised years ago and seems to be a little bit too small. It's also rolled a little bit for about a half inch and it appears that that part is a problem because sometimes it's hard to get the bowl to seal good.
CT has the entire assembly listed for not too much and I had considered getting that but I have heard bad things about their service and quality, and I'd really just rather repair what I have.
Any ideas?
I might not be able to check the board very often so if you could please e-mail suggestions to me
craymond@gwi.net
thanks.
Post a Followup
: Re: Fuel bowl problem on a Super M
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
