Re: Reply to 2500 or 574 help
Posted by Janicholson on June 16, 2007 at 07:06:07 from (66.173.50.174):
In Reply to: Reply to 2500 or 574 help posted by chadd on June 15, 2007 at 23:10:05:
The answer to hydraulic heating may be a combination of two things, In an open center system the return to resivoir valves/lines must be open causing zero pressure on the pump when all valves are in neutral, or float. If this is not the case it needs to be. A oil cooler with a fan if possible in the return line is also desirable. It needs to flow the 17 GPM of the pump. The carb may need to be cleaned, If it is varnished up some the main jet can restrict flow. The float level is another possible lean causing issue if it is a bit low in the bowl. Measure carefully. The third is that if it still needs choke, the main jet may need to be replaced, or drilled out. (drilling is not the best solution as it is hit or miss, and the drill sizes are in number drills, not fractional, and tiny increments are all that is needed. Do not drill anything unless you have a second main jet to take it back to where it was. A CO HC meter hooked to the exhaust can assist in setting the fuel/air ratio. If it needs choke, it needs adjustment and will suffer low power and heating till fixed. JimN
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
