A Carb troubles
Posted by Chad from Michigan on April 03, 2007 at 06:27:43 from (152.72.151.71):
Ok I am in need of some help. I have a zenith carb on my 1945 A.
when I got the tractor I got it running and have had the same problem since day one of getting it running.
When you throatal it up it hesitates and sputters then fianly gets up to speed. Its like it is starving for fuel. I did change the plugs and wires and still need to get a new dist. cap I did gap the points to .013 becasue its a mag.
It just acts like it is starving for gas. Now I know I didn't help matters that when I took it apart I put it in the bead blaster at work after tearing it completly apart. I know lots of people frown on it but I have had good luck in the past but they were on good running carbs in the first place.
Well it looks new and I have a good clear coat on it so it wont tarnish up.
anyway what do I need to look at? It still starves for gas and I can not get it to idle any different when I screw in the idle mixture screw. Just like on all my cubs 99% of the time that screw doesn't work. Only 1 or 2 times out of pure luck I have got the carb right and that works.
I tired putting a fine wire through the passeges of the carb but could only go so far. What should I do? Also new gas and sediment bulb assembly on the tractor so that isn't a problem. I also cleaned the screen on the inlet of the carb.
anyone have suggestions?
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
