Re: Behlen power steering 300
Posted by lawmar on March 06, 2007 at 12:20:02 from (64.73.67.49):
In Reply to: Behlen power steering 300 posted by ohioriverfarmer on March 05, 2007 at 19:00:12:
DON"T DO IT!!!!! If you take a behlen powersteering unit and put it on a tractor that did not have power steering you won"t be able to do it. There is a flow divider valve that is not present on your tractor. If it was there you don"t want to do it anyway. We have taken several 400-450 Farmall tractors with factory Behlen units on them and fixed them with a seperate powersteering pump. Why? The factory flow divider valve was one of the weaknesses of these tractors. You have to split off some of the flow form the hydraulics for you power steering to work. Here is a better solution. What you do if your mechanically not all that good is take an eaton pump from a char lynn system and mount it up front to power your behlen unit. If your mechanically capable and want to really do it right this is what you do. Take a Ford power steering pump circa 1969 or so and mount it up under the hood on the left side. Then if you alreay have not done so mount an alternator on the right side. Run your belt from the fan pulley up to the alternator and then across right below the top radiator hose and to the power steering pump and than back down to the fan pulley. Mount the power steering pump solid and use the alternator for your tension adjust. If you do this you will have a system that works better than Char Lynn. You will be much happier if you do it that way. Trust me. With it idling and staionary you will be able to take your pinky and turn the wheel. If anyone says it can"t be done then I say don"t interput me cause I"ve alreayd done it. I plan to do it on a Farmall M this summer however I will using an eaton pupm similar to the Char Lynn eaton pump but mounting up on top on the left side and belting it like above. The late 50s and early 60s ford power steering pumps were an eaton pump. Most Semi-Tractors form this era were a similar eaton pump. They are a dime a dozen if your capable of build a mounting system. The late 60s Ford pumps are great because of the built in reservoir. DO NOT USE A GM PUMP form the same era. They do not have enough power at the low RPMs. The ford pump will produce 1600 lbs of pressure even when it is barely turning.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
