Farmall Tractors Discussion Board
I the Red, now have De-Danged the 51 Farmll H. RUNNING GREAT!!!
Posted by The Dang Ol Red, John Fritz on April 24, 1999 at 10:54:28:
I spent the whole morning taking my time on the head and the valves. All the headbolts around #2 and #3 had loosened up a tad but not much. The two center bolts between #1-2 and #3-4 were somewhat loose. The front and back bolts were on the nose.
Now on the valve clearances. #1 exhaust was not closing. Clearances on #2 and #3 were way too loose. #4 was fairly close but a little loose. This time after the intake valve closed on #1/4 with the starter, I then turned the engine with the crank until the mark was on TDC. Same thing on #2/3 except turning the mark to the bottom by hand. I did this 6 times. Finally the last 2 times on each cylinder the gaps were at .20 on the nose. I think I was passing by full compression when I was setting them at hour 2.
Going to buy 2 carbs for $80 and get an IH kit. I figure between the 3 I will get a good carb.
I need a spring set for the distributor but it isn't that far off.
I am much relieved that this H is finally behaving.
Post a Followup
: Re: I the Red, now have De-Danged the 51 Farmll H. RUNNING GREAT!!!
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
