Re: Timing a IH 140 - best method
Posted by Nat 2 on February 23, 2007 at 11:44:33 from (64.80.110.27):
In Reply to: Timing a IH 140 - best method posted by Nawlens Gator on February 23, 2007 at 08:38:22:
The difference in distributor angle could be due to any number of reasons, most likely because someone had the distributor off the tractor and didn't get the distributor drive gear lined up quite the same. Also, timing will be different on every tractor. How can the timing mark on the crankshaft pulley be fading away? It's a V-notch machined into the cast pulley. Is something rubbing on the pulley? If nothing is rubbing on the pulley, it is not fading or wearing. At worst, the layer of grease and dust is getting thicker. A quick scrape will return the timing mark back to its original luster. To time, you find top dead center on the compression stroke for cylinder #1 (front). TDC can be found by slowly rolling the engine over by hand with your thumb over the open spark plug hole until you feel air pushing past. Line up the timing marks at this point. Pull the distributor cap. The rotor should be directly underneath the #1 post on the cap. If it isn't, rotate the distributor until it is. A timing light is a waste of time. You need to time the tractor by ear to find the sweet spot where it accelerates smoothly when the throttle is quickly jerked from idle to full. Start the tractor and set it for a fast idle. Roll the distributor a little at a time until the tractor starts stumbling. Roll back the other way until the tractor starts stumbling. That's your range. Now find the first sweet spot where you get the smoothest idle. Now jerk the throttle to wide open. If it accelerates smoothly, it's timed. Otherwise, move it a little and try again. If you get it "too screwed up," the engine won't run. If you're only a little screwed up, the engine won't run very well, and could sustain damage if run hard for long periods of time in this state. Being a tiny bit off will not hurt anything.
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
