Farmall Tractors Discussion Board
51 Farmall H at 6.5 hours
Posted by The Red, John Fritz on April 23, 1999 at 06:31:15:
I pulled the spark plugs and had to give all 4 a wire brushing. The H is still running a bit rich at idle. So another carb is on my list. All 4 plugs are definitely firing. #2 plug appeared to have a tad of oil on it but I mean a tad. Rings may not be seated in yet.
Distributor needs a new set of springs but otherwise in good shape with good bushings on the dist. shaft.
Rear seal is definitely leaking but not a gusher. Someday I will have to split it and take care of that problem.
Minor leaks on the oil pan gasket. That will be permatexed when I change oil at 10 hours.
Governor is responding excellently. I will have to turn the screw on the butterfly shaft under the slanted lid a bit so the engine speed will start to speed up a little earlier while pulling on the throttle lever.
Still have to get a 12 volt generator and regulator. Lights work fine.
Front bolster is solid. No shimmy at road speed.
Cooling system is working fine with no leaks. She heats right up to 160 degrees or so.
That is all I have to report for now.
Post a Followup
: Re: 51 Farmall H at 6.5 hours
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
