If you are not getting poor quality rebuilt alternators, or have high electrical demand due to added accessories, the most likely problem is faulty wiring. Excess voltage will cause failure due to over heating. Those alternators will fail if run at maximum output for too long a period of time.
A poor connection can cause the regulator to demand maximum output from the alternator. Inspect the main wire from the solenoid battery post to the alternator output stud. Make sure that you do not have a poor connection between the connector and the wire. If that wire is good you should be boiling the batteries if the voltage is too high. Inspect the junction block and the wires going from the solenoid to the junction block, to the regulator. A poor connection there can cause low voltage at the regulator which again will cause the regulator to demand higher voltage.
With the system working you should not see more that 15 volts at the alternator output terminal, usually less than 14.5 volts. You should have no more than .1 volt drop across any connection. If you have .5 volt difference from the alternator output to the battery terminal on the regulator you are going to have problems.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
