Posted by charles todd on March 17, 2009 at 21:39:27 from (205.242.95.137):
In Reply to: voltmeter setup posted by JeremyG on March 17, 2009 at 20:31:28:
With a voltmeter you hook the positive to the ignition coil switched hot and the negative to ground (with a negative ground system). The reason for this is so when you shut off the key it turns off the voltmeter. If you do not have a key, like on a mag system, I suppose you could run it through an oil pressure switch. As for the "other wire" it is probably for a light bulb. It will be obvious if it has a light, it will be a wire out the center of the voltmeter. Wire the light to the headlights or dashlights.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
