Farmall Tractors Discussion Board
51 Farmall H Update and website update
Posted by The Red, John Fritz on April 05, 1999 at 07:54:16:
The Finale page is updated on my site. The tinwork is now painted along with the seat parts. I got a new spring and shock absorber and another used seat bracket that was hardly weathered at all. I will probably replace the tin down the road.
I have the light shells mounted and HOPEFULLY I have a good ground on each one. I did some carefull filing this time around to make sure I have a ground from the light base to the deck.
I have to work on the oil pressure guage line. It is leaking at the base next to the oil filter. Might have to get another line.
I drained the liftall yesterday. Good news, clean oil. Bad news, only 1/2 quart came out. Since it was hooked up, I bet I have damage to the pump.
I will pull the rocker arm assembly tonight and re-torque the head bolts. I will of course re-check valve gap clearances when I re-install the rocker arms.
At hour 10 I will change oil, filter, drain the water and add anti-freeze and prob. replace the water jacket inspection plate with one that is not as pitted. I will also drop the oil pan and apply red silicone sealer to the pan and gasket.
At the end of this week I will add the decals.
I have spent 40 hours over the last 4 days and I am tired. I came to work to rest. :)
Post a Followup
: Re: 51 Farmall H Update and website update
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
