Farmall Tractors Discussion Board
What Have I Got Here ??
Posted by Eddie Petty, Courtland, Va. on April 04, 1999 at 12:28:09:
I was rummaging thru a deceased farmer friends' out buildings yesterday when I uncovered a IH power unit. The engine is the typical in-line four cylinder EXACTLY like the engines in my '44 A and '44 B. Attached to the clutch housing is what appears to be a speed decreaser. The unit has a self contained radiator and fan assembly again very similar to the A and B. The bellhousing is quite short and the clutch is operated by a manual lever on the right side. The unit has an attached gas tank of approximately five gallons. The starter (which is missing) mounted to the front of the flywheel (unlike the A and B). The air breather is exceptionally tall and has a very fine screen mesh surronding the entire assembly. There are cast feet, two under the clutch housing and two under the radiator support. Provisions are also provided for a hand crank. The oil pan is flat bottomed and the block actually has a dip stick instead of the hi-lo oil cocks that I'm familiar with. The block serial number is MAM G and below that is 8822. The block casting date is 7*2*X.
Okay folks, what is it,how was it used and when was it built.
Post a Followup
: Re: What Have I Got Here ??
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
