Farmall Tractors Discussion Board
51 Farmall H came to life but running more like a Dang Ol Deere.
Posted by The Red, John Fritz on April 02, 1999 at 14:55:48:
After 2 long days I finally gave it a fire at 4:30. It started popping almost immediately. Open up the mix and then she came to life. Since I had worked some oil on the top of the pistons, she smoked for about 5 minutes then it cleared out. Oil pressure went right to 60 psi.
She only ran on 3 for a while and now on 4 but not smooth. I pulled each plug wire and all 4 plugs are working fine. I found the sweet spot on the timing and was only 10 degrees off or so.
She's running on 4 but sounds like 3 1/2. Its noisy under the valve cover so I suspect one of my clearances got loose.
Governor is not responding steadily. Prob. weak springs.
Gas bowl is leaking badly. Someone rigged in a cork gasket. My fault for not catching that.
So I suspect it will take a couple of more hours to work out the bugs and hopefully that #1 sleeve will settle down.
At least she is running a WHOLE LOT BETTER than before I tore it down.
That is it for now. I are tired. 14 hours yesterday and 9 today.
Post a Followup
: Re: 51 Farmall H came to life but running more like a Dang Ol Deere.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
