Posted by John T on March 08, 2009 at 14:59:26 from (71.55.26.69):
In Reply to: Farmall h problems posted by tgrewing on March 08, 2009 at 14:38:09:
Causes of premature point burn up may be:
1) Excess current cuz the ballast is undersized in cases with a 6 volt coil on a 12 volt tractor
2) Undersized or not connected or bad condensor
3) Condensor isnt well grounded
4) Points incorrectly gapped
NOTE you mentioned a resistor .......Normally a 6 volt tractor with a 6 volt coil WOULDNT HAVE ANY EXTERNAL BALALST RESISTOR
An 8 volt battery on a 6 volt system and 6 volt unballasted coil will cause minor premature points burn up cuz the points are switching a lil more current buttttttttttt If its a 6 volt coil and the condensor is good and wired in I wouldnt expect them to burn up all that much sooner. To be exact a smaller sized ballast would be used when running an 8 volt battery and a 6 volt coil...
Id check the condensor and its wiring n connection n ground,,,,,,,,look into that resistor situation as if its a 6 volt coil you dont need a regular sized ballast but a smaller ohms unit.......
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
