Farmall Tractors Discussion Board
50 H... what is this cable for???
Posted by Grant on March 30, 1999 at 10:09:25:
I'm restoring a 50 H ... rebuilt engine, including new pistons and sleeves, new this, new that ... you know the rest. This tractor was not running when I got it, and I've never seen what I'm going to inquire about on another H thus, this question.
There is a jacketed cable, like a choke cable, that is bolted to a bracket and attached to the arm that holds the belt pully rod. It has a large knob type handle, round like a shift knob. The other end enders the 'intermediate' case, on the right side of the tractor, in front of the hydralic ports. It passes through a hole that is bored through the case. If you remove the belt pully assembly, you can look inside and see the other end attached to some sort of slide, probably a valve, that goes what looks like into the trans case. It doesn't look like a cobbled job. Any ideas what it is? Obviously, the tractor is not running yet, but as soon as I run out of old parts to replace with new, I'll have her! Thanks, Grant
Post a Followup
: Re: 50 H... what is this cable for???
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
