Re: Need your help on a Farmall 706
Posted by Funtwohunt on March 16, 2009 at 18:53:48 from (63.172.252.203):
In Reply to: Need your help on a Farmall 706 posted by Tod in Ohio on March 16, 2009 at 18:16:16:
After you loosen the bolt you can either get the correct additional bolts needed to push the wedges apart to make them loose or you can use a grade eight bolt or a piece of hard shaft to knock the inside wedge loose then the outside wedge (the one that is against the 7/8" 12 pt bolt head. When I moved mine I jacked the tractor up and turned the wheel so the wedge is on the bottom of the shaft. They popped right loose. Make sure you recheck them after a few minutes and retighten them if needed. Funtwohunt weight of the wheel is
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
