If it has enough power to turn the engine, you should have enough to produce a spark [and completely irrelevant with a mag).
But, at the risk of stating the obvious, you're not getting fuel, spark, or maybe compression [if you're borderline there, a week battery won't spin it fast enough to pull in a good mixture or compress it as well either].
Soooo; after a few months, I'd suspect points or needle valve. Least messy (especially if you have an assitant) pull a plug wire and check for spark. If that's good, do you smell gas at the exhaust when it cranks? No? See if that carb is getting gas, if it doesn't have gas, it could be stuck needle valve, plugged line or bowl, [is the gas above the standpipe? BTW].
Well a couple obvious directions anyway; I don't have my H anymore, but that one and several others I've tinkered with were always pretty forgiving if they had gas in the carb and spark at the plugs.
This post was edited by spiffy1 at 09:09:45 03/16/09.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
