Re: '48 M need info
Posted by Haas on November 12, 2001 at 16:22:31 from (129.37.117.131):
In Reply to: '48 M need info posted by Busch on November 12, 2001 at 15:43:57:
The wheel on the side must be the belt pulley. Used with a flat belt to run equipment like feed grinders, blowers, threshers and so on. There were two kinds and several different sizes. They came in steel (not common) and paper. Yes, paper. They are made from compressed paper and resin mounted on a cast steel base. If it it still in good condition, and not lobsided, etc., do take it off and store in inside, not on a damp floor. If it gets wet, it may swell up and be ruined. There is a company that rebuilds the paper wheels, but it costs $150 or more. From your description, it sounds like you have a hyrdaulic Lift All (or commonly called a belly pump). That is a hydraulic pump and reservoir that is mounted up in the belly of the tractor under the main drive shaft just behind the clutch. If it is working, you should notice the tractor engine load up when you pull back all the way the activating rod located on the left side near the light bar. The pump only works when the clutch is engaged, so if you have been pulling the rod with the clutch depressed, nothing will happen. Put the transmission in neutral and release the clutch before pulling the rod. The oil level in the Lift all reservoir is checked at a cap that is just infront of the belt pulley on top of the clutch housing. The capped off pipe fittings are the pressure connections for the hydraulics, one on the right and two on the left. Hope this helps.
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
