Charging system problem solved!!
Posted by Haas on October 04, 2001 at 17:42:15 from (129.37.117.214):
For some time, I've been keeping the batteries charged on my MD with a small trickle charger. Of course it uses no electricity when running and I've found the two 6 volt batteries in series(it's a stock 12 volt system) will hold enough power for a lot of starts before I had to recharge. I had the generator rebuilt and an new regulator about a year ago, and they worked for a while. Today, I decided to dig into it to solve the problem. Found that the generator would charge when I grounded the field terminal. Measured the voltage with the field grounded and got over 16 volts. Also measured the resistance to a good ground from the base of the regulator and got about 5 to 6 ohms which I thought would be low enough and thus I figured the regulator was bad. Did not think to run a wire from the regulator base to a ground before I took the regulator off and to a shop to have it checked. They said the regulator checked good!! So back home, reinstall it and run a wire from under the base mounting lug to a good ground on the tractor. Problem solved!! I'm getting 25 amps or so and over 15 volts at the generator. The regulator is mounted on the radiator bracket and apparently, the painting I did a while back (with the regulator removed) and maybe paint under radiator attachements too kept the regulator from getting a good enough ground to make the generator work. Just thought I'd pass along the info.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
