Some weeks back I posted about my trouble learning ow to MIG weld and getting things to work right. Well, I got the job done and learned a few things along the way.
I changed to .024 wire from .035. That made supporting an arc without burn through on sheet metal easier. I discovered MIG needs DEAD CLEAN metal to work nice, at least in this case. When welding new sheet to new sheet I got real nice welds. When welding new sheet to old metal, even though it was ground to clean metal, the arc was different sounding and quality not so good. MIG sucks with rust, just useless. The CO2/Argon flow at the recommended 10lt/min wasn't enough, or my gauge is wrong. Getting a good weld on sheet with MIG appears to be a game of tiny adjustments with the material I was using. A little more wire speed here, a little less there. This was with my Cebora MIG unit. I'm getting the parts together to put the Miller 172 back into operation, but I don't think it's the welders problem, I think it's getting this old dog to learn new tricks!
