Custom front axle
mmkid
Do you guys think some 2x4x1/4 thick walled tube would be heavy enough for a front axle on a tractor that will pull up to 10,000 pounds? Thanks.
I think it is to heavy. Run braces from king pin up to the frame. Triangles are the stronger than anything.
He pulls to 6500 with this Moline. Never carries any front end weigh, mostly in the middle if he needs some.
