Radials on a puller
Probably won't be much difference. A radial performs better in the field due to running lower pressure and flexing more. On the track you need to keep the pressure up to not loose hitch height.
Bias are much harder. I switched from radial to bias both 23 degree firestone. Running around 10 psi less in the bias. The radials would still squat at the end of the track with 18psi in them and leave nice holes. I'm still learning the bias but 8-10 some tracks is too much
