phil51
Does anybody know who makes a decent D ring for pulling? I know Denny's makes one but is there anywhere else I could look? Thanks
I use weld on D rings that are used on semi-trailers. Comes with the weld on bracket and the D-ring. I just pitch the weld on bracket in the scrap pile. Lots of diameters and sizes available. You could also use a weld on Printle (spelling?) ring. They come in several sizes also. The last pulling hitch I made, I used the weld on Printle ring.
The nice thing about these is there is a tongue on them that is made to be welded to a frame. Works pretty well.
OTJ
I got mine from Northern Tool. In the winch section with chains and hold downs. Might try there as I am not sure what it is you are looking for.
