Wheel Adapters.
VicS
Location
SE Il.
Changing 9 hole adapters. I built these, bad design. I couldn't get inside bolts out. So silly like I cut the heads off.Well there is a taper on the head. Now I really have a problem. Had to cut adapter plum apart, and then weld nuts to every one. Thankfully all are out. You guys surely, think before you act, don't you.
i do something like that about ounce a year or as my wife thinks ounce a day,but i usualy can figure it out,but never can figure my wife out. going to have it ready for this year ?other day i was putting new rod bushings in rods press in and hone to fit simple enough seemed alful thickto hone out 40 thous. honed out about there and no brass left in bushing , that is what you get with advantage rod bushings ,will go get good ones from agco next chance i get and start over
I hope. Just a lot of little things. And I am slow. Today had to much company. But that is good. We never worked, just spit in the fire all morning.
